16 years agoFilter & decimation implementation on AD7401
Hello everybody! We have chosen the AD7401 Sigma Delta modulator for our project, translated the Verilog code given by the datasheet into VHDL and are now confused about the results of the simu...
14 years agoSir, Hello!
I used the code you write to debug to the actual circuit not simulation, and found it cannot produce word_clk clock signal, so I have written in verilog a divider circuit, to produce mclk and word_clk signal, and made ​​some changes to your program (Delete word_clk produce circuit ), and then debug, I find the result of the conversion are all 0 (DATA [15 .. 0]).After all, it cannot work in actual circuit.I don't know why,Could you tell me?Have you ever used the AD7401 to apply a actual project such as a sampling circuit of voltage? The following is a modified program of you: library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_unsigned.all; entity AD7401decimationfilter is port(reset, mdata, clk20,word_clk: in std_logic; DATA : out std_logic_vector(15 downto 0); ads_clk : out std_logic); end AD7401decimationfilter; architecture RTL of AD7401decimationfilter is signal CN2_D2,DN1_D,DN2_D,DN1,DN2,DN3 : std_logic_vector(24 downto 0); signal CN1, CN2 : std_logic_vector(24 downto 0); signal delta : std_logic_vector(24 downto 0); --signal word_count : std_logic_vector(7 downto 0); --signal word_clk : std_logic; begin ads_clk <= clk20; p11:process(clk20, reset) begin if reset = '0' then delta <= (others => '0'); elsif clk20'event and clk20 = '1' then -- if mdata = '1' then delta <= delta + 1;--mdata; --end if; end if; end process p11; p12:process(reset, clk20) begin if reset = '0' then CN1 <= (others => '0'); CN2 <= (others => '0'); elsif clk20'event and clk20 = '1' then CN1 <= CN1 + delta ; CN2 <= CN2 + CN1; end if; end process p12; --DECIMATION STAGE (MCLKIN/WORD_CLK) --process(clk20,reset) --begin -- if reset ='0' then -- word_count <= "00000000";--(others => '0'); -- elsif clk20'event and clk20 = '0' then -- if word_count="11111111" then -- word_count<="00000001"; -- else word_count <= word_count + 1; -- word_count is an 8 bit reg for decimation 2^8= 256 -- end if; -- end if; --end process; --process(word_count,reset) --begin --if reset = '0' then -- word_clk <= '0'; -- oe<='0'; --else -- word_clk <= word_count(7); -- oe<=word_count(7); --end if; --end process; p13:process(reset, word_clk) begin if reset = '0' then CN2_D2 <= (others => '0'); DN1_D <= (others => '0'); DN2_D <= (others => '0'); DN1 <= (others => '0'); DN2 <= (others => '0'); DN3 <= (others => '0'); elsif word_clk'event and word_clk = '1' then DN1 <= CN2 - CN2_D2; DN2 <= DN1 - DN1_D; DN3 <= DN2 - DN2_D; CN2_D2 <= CN2; DN1_D <= DN1; DN2_D <= DN2; end if; end process p13; --p14:process(word_clk,reset) --begin -- if reset = '0' then -- DATA <= (others => '0'); -- elsif word_clk'event and word_clk = '1' then -- DATA(15 downto 0) <= DN3(23 downto 8); -- extracting the Most Significant Bits MSB -- end if; --end process p14; process(clk20,reset) begin if reset = '0' then DATA <= (others => '0'); elsif clk20'event and clk20 = '1' then if word_clk = '1' then if DN3(24) = '1' then DATA(15 downto 0) <= (others => '1'); else DATA(15 downto 0) <= DN3(23 downto 8); end if; end if; end if; end process; end RTL; *i wrote it myself sub-frequency signal procedure as follows: module dividefrequency(sysclk,reset,mclk1,mclk2,word_clk); input sysclk; input reset; output mclk1; output mclk2; output word_clk; wire sysclk; wire reset; reg mclk1; wire mclk2; reg word_clk; reg [31:0] div_count; reg [7:0] word_count; integer location; integer info_file; //wire [7:0] dec_rate; //parameter rate=256;//280wen,256(12M);//70->1/2 i2c//116->1.4*16; //parameter h_rate=64; //assign dec_rate = 256 - rate;//ini value assign mclk2=mclk1; /* initial begin end */ /*divide sysclk 50MHZ to 6.25MHZ*/ always @(posedge reset or negedge sysclk) if(reset) begin div_count<=0; end else begin div_count<=div_count+1; if(div_count==8) div_count<=1'b1; end always @(div_count,mclk1)//mclk begin if(div_count<=4) mclk1<=1; else if(div_count<=8) mclk1<=0; end always @ (negedge mclk1 or posedge reset) begin if (reset) word_count <= 0; else if (word_count == 8'hFF) word_count <=1;// dec_rate+1; else word_count <= word_count + 1; end /* always @ (word_count) word_clk <= word_count[8]; */ always @ (word_count) begin if(word_count<=64)//64) word_clk<=1; else if(word_count<=8'hff)//255) word_clk<=0; end endmodule sysclk is 50mhz,which is divided to 6.25mhz as mclk and 24.41khz as word_clk.
