16 years agoIf you specify the timing correctly, Quartus timing analysis will care for it. 5 ns output delay is only part of the involved delay, the ADC has most likely more delay. The problem is common to interfacing external devices.
If you don't need correct measrements from the start, you don't need a reset with your design, I think. You have to check, if it has illegal states, that may cause a dead-lock.
