14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and forth and to check the transmission somehow. I am using two Altera Transceiver Signal Integrity Development Kit, Stratix IV GT (EP4S100G2F40I1) boards.
Please help to advice if anyone knows such tutorials and examples. Also, any suggestions are highly appreciated. Thanks.49 Replies
--- Quote Start --- What was the problem you saw? --- Quote End --- You can see the problem I have during the process of generating HDL files for the Qsys system in the attached file. The generation hangs for ever with the last msg as "Info: Starting classic module elaboration." --- Quote Start --- If you think its a problem with Windows Server 2008, download VirtualBox, install Windows or Linux into that, and then install the Quartus tool there. --- Quote End --- I tried Virtual Machine before, but there is an issue with licensing as Altera does not support the virtual NIC address. Do you know if the license works with Quartus installed in a VirtualBox?. --- Quote Start --- Note that Windows Server 2008 is not a supported OS: If you're serious about FPGA design, then you should install a supported OS. --- Quote End --- I have thought of this option before, but I need to confirm that the problem comes from the OS first. The servers are not my personal PCs so reinstalling would be a second choice. Thank you. - Altera_Forum
--- Quote Start --- I have installed Q II 11.1 SP1, exactly the Build 216 11/23/2011 SJ Full Version. Unfortunately, no change was made in the process of generating any designs that include a On-Chip Memory IP core. The latest one I tried was the JTAG-to-Avalon-MM tutorial you suggested. Hence, I attach here so that you can check whether the issue is coming from the design itself or it is not possible to use On-chip memory cores in Qsys/SOPC Builder in my system (Windows Server 2008). --- Quote End --- Here's what I did: 1) Unzip your design 2) Opened the Qsys design and generated the system 3) Clicked on the files tab in the main GUI, and then clicked on the qsys_system.qsys and set it as the top-level entity (as described in the tutorial). 4) Synthesized the design. There were no errors. What was the problem you saw? If you think its a problem with Windows Server 2008, download VirtualBox, install Windows or Linux into that, and then install the Quartus tool there. Note that Windows Server 2008 is not a supported OS: http://www.altera.com/download/os-support/oss-index.html If you're serious about FPGA design, then you should install a supported OS. Cheers, Dave - Altera_Forum
--- Quote Start --- My point was that if I want a throughput higher than 1000Mbps, I think that I have to transfer data to device using Ethernet interface and store it somewhere before sending it out. Because without storing data on board, how can I have like 10Gbps with input data rate to board is no greater than 1000Mbps? --- Quote End --- Now you understand the problem with this kit. The Signal Integrity kit is useful for looking at Signal Integrity, and that is about all. Because it does not have 10Gbps connectors, it is not the appropriate kit to try and develop 10Gbps applications. However, now that you have purchased the kit, you have to figure out what tests you can perform. If the board has two transmitters and two receivers on the SMA connectors, then you could use two SMA-to-SPF+ adapters. You could then connect two SFP+ cables to a desktop 10Gbps SFP+ card or to two ports on a 10Gbps switch. That way you can have 10Gbps continuous through the link. The alternative is to use the 1Gbps interface to fill a buffer in the FPGA, or several buffers, and then send the data over 10Gbps. To maximize bandwidth, you could just send the same data 10x. Cheers, Dave - Altera_Forum
--- Quote Start --- For example, you can use a direct attach copper cable with an SMA breakout. This would allow you to create a copper connection to an SFP+ switch. --- Quote End --- This is clear for me. Now, I can imagine how to to connect to an SFP+ module. --- Quote Start --- Look at the board. It has an ethernet connector. You can use that to transfer data to the board. If you then want to send it via 10Gbps, sure, use an SMA connector to send it somewhere else. --- Quote End --- My point was that if I want a throughput higher than 1000Mbps, I think that I have to transfer data to device using Ethernet interface and store it somewhere before sending it out. Because without storing data on board, how can I have like 10Gbps with input data rate to board is no greater than 1000Mbps? --- Quote Start --- If you want to implement a x1 PCIe cable to your SI kit, you have to find the transceivers that exist on the board *and* can be used to implement PCIe using the hard IP block. --- Quote End --- I will figure out this later and return to discuss if I face any issue. Thank you very much. - Altera_Forum
--- Quote Start --- No, that is 11.1. Once you've installed SP1, it'll change to something like: Quartus 11.1 Build 216 11/23/2011 SJ Full Version Cheers, Dave --- Quote End --- I have installed Q II 11.1 SP1, exactly the Build 216 11/23/2011 SJ Full Version. Unfortunately, no change was made in the process of generating any designs that include a On-Chip Memory IP core. The latest one I tried was the JTAG-to-Avalon-MM tutorial you suggested. Hence, I attach here so that you can check whether the issue is coming from the design itself or it is not possible to use On-chip memory cores in Qsys/SOPC Builder in my system (Windows Server 2008). Thank you very much. - Altera_Forum
--- Quote Start --- So, the SFP+ optical module will connect directly to SMA connector? Sorry if this is a lazy question:( --- Quote End --- No. If you want to connect to an SFP+ module, then you need a SPF+ cage. Since the SI kit does not have it, you'll need another solution. For example, you can use a direct attach copper cable with an SMA breakout. This would allow you to create a copper connection to an SFP+ switch. --- Quote Start --- Do you mean that data is transmitted from host PC to device via Ethernet PHY interface, then stored in on-chip memory/buffer before being sent out? If so, the real data rate is 1000Mbps as maximum, instead of 10Gbps? --- Quote End --- Look at the board. It has an ethernet connector. You can use that to transfer data to the board. If you then want to send it via 10Gbps, sure, use an SMA connector to send it somewhere else. --- Quote Start --- I have checked and the PCIe hard IP is available on ST IV. I will learn this solution later. Can you provide some related material/tutorial. --- Quote End --- I know the IP is available. That was not what I told you to look at. If you want to implement a x1 PCIe cable to your SI kit, you have to find the transceivers that exist on the board *and* can be used to implement PCIe using the hard IP block. Those transceivers might be on SMA connectors, or they might be on the Airmax VS connectors, or they might not be available at all. That is what you have to figure out! Cheers, Dave - Altera_Forum
--- Quote Start --- The external PHY is the chip on that HSMC board. If you look at the price of a GX FPGA plus the external PHY, you'll find that it is less than the price of a GT FPGA. However, the board layout will then need more chips, so you need to figure out what is the cost effective solution for your final design. --- Quote End --- Now I got the point, actually this answers my wonder before that why SIV GX board is much cheaper then the SIV GT Transceiver SI board. --- Quote Start --- The GT boards have 10Gbps transceivers, so they do not need the external PHY. --- Quote End --- So, the SFP+ optical module will connect directly to SMA connector? Sorry if this is a lazy question:( --- Quote Start --- The kit does have a 1000Mbit PHY, so that is about all you can use. --- Quote End --- Do you mean that data is transmitted from host PC to device via Ethernet PHY interface, then stored in on-chip memory/buffer before being sent out? If so, the real data rate is 1000Mbps as maximum, instead of 10Gbps? --- Quote Start --- The other option would be to build a board that interfaces to the FCI Airmax VS connectors, but you'd need to check the hardware design to see if the PCIe hard-IP was available on those transceivers. If it was, then you could build a x1 PCIe breakout cable, and then connect to the board using one of the adapters from OneStopSystems: --- Quote End --- I have checked and the PCIe hard IP is available on ST IV. I will learn this solution later. Can you provide some related material/tutorial. Thanks! Best, PLMT. - Altera_Forum
Quartus 11.1 Build 216 11/23/2011 SJ Full Version Cheers, Dave - Altera_Forum
--- Quote Start --- Try 11.1sp1. The tutorial was tested under Windows XP and 7, Linux Centos 6.2 and Ubuntu 11.10. There were no problems with that version of Quartus. --- Quote End --- My current Quartus is 11.1 Build 173 11/01/2011 SJ Full Version. I just installed this several weeks ago. I think this is 11.1sp1, isn't it? The system is Windows Server 2008, if this is where the problem can come from? - Altera_Forum
--- Quote Start --- By external PHY, do you mean something like the "Dual XAUI to SFP+ HSMC" board for connecting SFP+ modules in case of Stratix IV GX? --- Quote End --- The external PHY is the chip on that HSMC board. If you look at the price of a GX FPGA plus the external PHY, you'll find that it is less than the price of a GT FPGA. However, the board layout will then need more chips, so you need to figure out what is the cost effective solution for your final design. --- Quote Start --- As fas as I know, people has tested 10Gbps Ethernet with Stratix IV GT (but in 100G SIV GT dev board) in http://www.alterawiki.com/wiki/10g_ethernet_and_10g_base_r_phy_interoperability_hardware_demonstration_design. Acording to the block diagram, they connect directly to SFP+ Optical module without an external board or PHY. If you can help to correct my understanding and clarify? --- Quote End --- The GT boards have 10Gbps transceivers, so they do not need the external PHY. --- Quote Start --- Testing with PRBS generator is what I want now. But, later on, I need to read data in terms of multimedia file like a movie file from host PC, store in some on-chip memory or buffer, then transmit in packets to other boards. So, I am wondering how should I do that and what is the most suitable solution. I wait for your advice also:) --- Quote End --- Transferring data over PCIe would be suitable. However, since you purchased the GT signal integrity kit, you do not have that option. http://www.altera.com/products/devkits/altera/kit-stratix-iv-gt-si.html The kit does have a 1000Mbit PHY, so that is about all you can use. The other option would be to build a board that interfaces to the FCI Airmax VS connectors, but you'd need to check the hardware design to see if the PCIe hard-IP was available on those transceivers. If it was, then you could build a x1 PCIe breakout cable, and then connect to the board using one of the adapters from OneStopSystems: http://www.onestopsystems.com/components.php Cheers, Dave
