14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years ago --- Quote Start --- By external PHY, do you mean something like the "Dual XAUI to SFP+ HSMC" board for connecting SFP+ modules in case of Stratix IV GX? --- Quote End --- The external PHY is the chip on that HSMC board. If you look at the price of a GX FPGA plus the external PHY, you'll find that it is less than the price of a GT FPGA. However, the board layout will then need more chips, so you need to figure out what is the cost effective solution for your final design. --- Quote Start --- As fas as I know, people has tested 10Gbps Ethernet with Stratix IV GT (but in 100G SIV GT dev board) in http://www.alterawiki.com/wiki/10g_ethernet_and_10g_base_r_phy_interoperability_hardware_demonstration_design. Acording to the block diagram, they connect directly to SFP+ Optical module without an external board or PHY. If you can help to correct my understanding and clarify? --- Quote End --- The GT boards have 10Gbps transceivers, so they do not need the external PHY. --- Quote Start --- Testing with PRBS generator is what I want now. But, later on, I need to read data in terms of multimedia file like a movie file from host PC, store in some on-chip memory or buffer, then transmit in packets to other boards. So, I am wondering how should I do that and what is the most suitable solution. I wait for your advice also:) --- Quote End --- Transferring data over PCIe would be suitable. However, since you purchased the GT signal integrity kit, you do not have that option. http://www.altera.com/products/devkits/altera/kit-stratix-iv-gt-si.html The kit does have a 1000Mbit PHY, so that is about all you can use. The other option would be to build a board that interfaces to the FCI Airmax VS connectors, but you'd need to check the hardware design to see if the PCIe hard-IP was available on those transceivers. If it was, then you could build a x1 PCIe breakout cable, and then connect to the board using one of the adapters from OneStopSystems: http://www.onestopsystems.com/components.php Cheers, Dave
