14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years ago --- Quote Start --- The external PHY is the chip on that HSMC board. If you look at the price of a GX FPGA plus the external PHY, you'll find that it is less than the price of a GT FPGA. However, the board layout will then need more chips, so you need to figure out what is the cost effective solution for your final design. --- Quote End --- Now I got the point, actually this answers my wonder before that why SIV GX board is much cheaper then the SIV GT Transceiver SI board. --- Quote Start --- The GT boards have 10Gbps transceivers, so they do not need the external PHY. --- Quote End --- So, the SFP+ optical module will connect directly to SMA connector? Sorry if this is a lazy question:( --- Quote Start --- The kit does have a 1000Mbit PHY, so that is about all you can use. --- Quote End --- Do you mean that data is transmitted from host PC to device via Ethernet PHY interface, then stored in on-chip memory/buffer before being sent out? If so, the real data rate is 1000Mbps as maximum, instead of 10Gbps? --- Quote Start --- The other option would be to build a board that interfaces to the FCI Airmax VS connectors, but you'd need to check the hardware design to see if the PCIe hard-IP was available on those transceivers. If it was, then you could build a x1 PCIe breakout cable, and then connect to the board using one of the adapters from OneStopSystems: --- Quote End --- I have checked and the PCIe hard IP is available on ST IV. I will learn this solution later. Can you provide some related material/tutorial. Thanks! Best, PLMT.
