10 years ago
error: expression is not constant
My code is as followed:
signal cnt_clks                       : natural range 0 to 300;
cnt_clks        <= conv_integer(unsigned(time)) * 25;
 process(clk_50, reset)
    begin
        if reset = '1' then
            enc_delay       <= (others => '0');
            enc_delay_in    <= '0';
        elsif rising_edge(clk_50) then
            enc_delay(cnt_clks downto 0)     <= enc_delay((cnt_clks -1) downto 0) & enc_in(1);
            enc_delay_in                     <= enc_delay(cnt_clks);
        end if;
    end process;
Modelsim compiles it with no problem. Quartus shows the 'Expression is not constant' error (I'm using Quartus 15). How can I overcome that?
I tried defining cnt_clks as Integer, no luck.
Roy
    --- Quote Start ---
    Do you really have a signal called "time" ? I'm surprised this doesn't conflict with the standard TIME type.
    --- Quote End ---
    time is not a reserved keyword, nor are any type names. So you can use it to confuse yourself thoroughly (and it works because VHDL is all context driven)
    signal time : std_logic;
    signal std_logic : integer range 0 to 153;
    signal integer : real range -0.1 to 100.66;
    You could rewrite your assignment with a for loop that goes through each bit of enc_delay and either shifts it or keeps it depending on the value of the index compared to cnt_clks.
    It doesnt matter how enc_delay is calculated - quartus only supports slicing an array with a constant. And in your case your code implies slicing a variable number of bits out of an array, which is not possible with VHDL.
    what is definition for enc_delay. Hope it declared properly for at least 300 bits long. The size should be greater then maximum value of {cnt_clks} 300.
    it seems shift register that should shift for random number bits. How do you think synthesis tool could implent your code?
