Error (209014): CONF_DONE pin failed to go high in device 1.
Hi Sameer,
Apologies for the delayed response.
Could you please refer to the following KDB articles for this specific CONF_DONE error?
- https://community.altera.com/kb/knowledge-base/why-do-i-receive-the-error-conf-done-pin-failed-to-go-high-in-device-x-when-i-tr/347292
- https://community.altera.com/kb/knowledge-base/error-conf-done-pin-failed-to-go-high-in-device-/340233
Please also try programming with the attached .sof file and confirm whether the same error is observed.
For the next step, could you please try the following?
- Keep all DIP switches at the factory default setting.
- Remove any external connection or daughter card from the board.
- Power cycle the board.
- Program only the official example .sof file from the Cyclone V E Development Kit design package.
- If probing is available, please check the CONF_DONE, nSTATUS, and nCONFIG signal levels during programming.
Also, could you confirm how many Cyclone V E development kit boards show this same behavior out of the total boards tested?
Fakhrul
- Sameer-sahu2 months ago
Hi FakhrulA_altera ,
I have tried all the steps suggested by you. But still I am getting the same error. The DPI switchs are place by default attached in my previous message. How to check my JTAG is working or not?- FakhrulA_altera2 months ago
We would like to check if there are any updates regarding this issue.
As we have not received a response to our previous follow-up, this thread will be transitioned to community support. We hope your concerns have been addressed.
Should you require further assistance, please feel free to open a new thread. Otherwise, community users may continue to assist here.
Thank you.
I will try this and let you know.
