8 years ago
Error (10779): VHDL error at memory.vhd(30): expression is not constant
Hello, i have an issue on this vhdl code, i need to increment the index of my vector to fill up a memory. the problem is that quartus reports me this error when i try to put a variable as an index like ( A downto B) where A and B are variables...
thank you for the help!
here is the code:
  1. LIBRARY ieee;
  2. use IEEE.STD_LOGIC_1164.ALL;
  3. use IEEE.STD_LOGIC_SIGNED.ALL;
  4. USE ieee.numeric_std.all;
  5. USE std.standard;
  6. entity memory is
  7. Port ( Clk : in std_logic; -- processing clock
  8. wr : in std_logic; -- write enable signal
  9. cs : in std_logic ;-- select memory
  10. rd : in std_logic; -- enable reading from memory
  11. add : in std_logic_vector(9 downto 0); -- write address to store the data into ram
  12. data_in : in signed(7 downto 0); -- input data to store into ram
  13. data_out : out signed(7 downto 0)); -- output data from memory
  14. end memory;
  15. architecture Behaviour of memory is
  16. signal tmp: integer range 0 to 1023 := 0 ;
  17. signal tmp1,tmp2: integer range 0 to 8184:= 0;
  18. signal storage: signed (8184 downto 0);
  19. begin
  20. tmp <= to_integer(unsigned(add));
  21. tmp1 <= 7+ tmp*8;
  22. tmp2 <= tmp*8;
  23. process(Clk)
  24. begin
  25. if Clk'event and Clk = '1' then
  26. if (wr = '1' and cs='1') then -- In this process writing the input data into memory
  27. storage(tmp1 downto tmp2) <= data_in;
  28. end if;
  29. if (cs='1' and rd='1') then
  30. data_out <= storage(tmp1 downto tmp2) ;
  31. end if;
  32. end if;
  33. end process; -- asynchronous reading from memory
  34. end Behaviour;
    According to VHDL rules, you should use this straightforward coding
    storage(7+ tmp*8 downto tmp*8) <= data_in;
    data_out <= storage(7+ tmp*8 downto tmp*8);
    Even more straightforward, an array 1024x8.
    Why have you got such a large signed number? if you are intending on using a ram you should use an array of signed, not a single signed, and then index to a single element on any given clock cycle.
    Which line is line 30?
    Could you edit your post so it is using code tags so the formatting isa bit better?
