8 years agoError (10779): VHDL error at memory.vhd(30): expression is not constant
Hello, i have an issue on this vhdl code, i need to increment the index of my vector to fill up a memory. the problem is that quartus reports me this error when i try to put a variable as an index li...
8 years agoWhich line is line 30?
Could you edit your post so it is using code tags so the formatting isa bit better?
