15 years agoError 10200
Hi Everyone,
When trying to synthesize the following code I get the error: Error (10200): Verilog HDL Conditional Statement error at prog_counter.v(62): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct The code is from the book Verilog Coding for Logic Synthesis by Weng Lee (Ch. 6) What generally causes this type of error? Here is the code with the problem line indicatedalways @(ceb or write or reset or load or data_in)
begin
if (~ceb & write & ~load & ~reset & ~flag_counter)
control_word_register = data_in ;
else if (~ceb & ~write & load & ~reset & ~flag_counter)
latch_counter = data_in;
else if (ceb & ~reset)
begin
//reset the control word counter
control_word_register = 0;
//reset the latch
latch_counter = 0;
end
else if (disable_CWR)
end
//to counter for counter
always @(posedge clk or posedge reset or posedge trigger)
begin
if(reset)
begin
disable_CWR <= 0;
flag_counter <= 0;
counter <= 0;
flag_half_counter<=0;
end
else
begin
>>Error << if(control_word_register) //counter is enabled << *****Error 10200 Here******
begin
if(control_word_register == 2'b00) //this if for one shot mode
begin
if(~flag_counter)
begin
counter <= latch_counter;
flag_counter <=1;
end
else
begin
if(counter == 8'hff)
begin
//to stop counter for one shot mode
disable_CWR <= 1;
flag_counter <=0;
end
else
counter <= counter + 1;
end
end
else if (control_word_register == 2'b01) //waveform generator mode
begin
if(~flag_counter)
begin
flag_counter <= 1;
end
else
begin
flag_counter <= 0;
end
end
else if(control_word_register == 2'b10) //this if for the 5-% duty cycle waveform generator
begin
if(~flag_counter)
begin
flag_counter <= 1;
end
else
begin
if (counter == {1'b0,latch_counter})
begin
flag_half_counter <= ~flag_half_counter;
counter <= counter - 1;
end
else
if (counter == 0)
flag_counter <= 0;
else
end
end
else if(control_word_register == 2'b11)//this is for triggered pulse generator mode
begin
if(~flag_counter)
begin
//If we aren't currently sending out a pulse, then keep the counter loaded and ready
//this also resets the counter after a successful pulse is generated so that we will be ready for the next trigger
if(trigger)
flag_counter <= 1;
else
flag_counter <= 0;
end
else
begin //stop counter for triggered pulse mode
flag_counter <= 0;
end
else
end
end
end
end The Problem appears in the second always block on the line if(control_word_register) //counter is enabled << *****Error 10200 Here****** Any input on this is really appreciated...2 Replies
Thank you, I had the same problem. Worked for me too.
Figured it out, it was the fact that the second always block was sensitive to the trigger. I removed it from the event list and just sync the trigger to the clock before it reaches this module.
