EPM7128AE - strange FlipFlop behaviour
I use the scematic on EPM7128AE you'll see in schaltung.jpg.
There is a pixelclock (signal 3) which should comes out of the JK-FlipFlop with half the frequency. This works fine but sometimes there is only a short puls out of the JK-FF and the signal flips back to old state. Line 2 should be a Puls on every edge. I'm sure that it's not a problem of the CLRN of the JK-FF. Maybe it has to do with slew rates or something like this. I tried 'Slow Slew Rate' ON, but still the same problem. I use Quartus II V8.1. Daniel6 Replies
--- Quote Start --- When I do not use the Input for a rippleclock, is it enough to use only one DFF to synchronize it with my clock? --- Quote End --- Altera recommends using always 2-stage sync, but I'm using it only in special cases. - Altera_Forum
I have tested the 'double DFF' as in schematic2.jpg and it works! Thank you!
It's normal behaviour with unrelated signals. A single DFF isn't enough synchronization to use the output as a ripple clock. It should work with a second DFF level. If the delay is an issue, you can operate both FF'S on different clock edges.
Trace2 is related to Trace4 and the signal is generated inside the CPLD and comes out of a Pin of the device.
Trace 3 and 4 are intern signals,which I temporarly routed to an outputpin to trace it with my scope (because I noticed the behaviour of Trace 2). I think there is a glitch or spike in front of the edge of Trace 3 when it comes to an extra toggle. Sometimes there I can see something like a spike. You wrote: Most likely setup or hold timing of inPIX_CLOCK has been violated here. That's what I can't understand, because inPIX_CLOCK is a signal coming from another device. I have no possibility to change it. So I used a DFF to get it synchronous to my internal clock, which is coming from a 80MHz-Oscillator (on global clock pin 'clk'). - Altera_Forum
If the device ois powered correctly, the reason for the observed behaviour is most likely a timing violation at the circuit inputs. But these signals are shown in the waveforms, I think. Trace 2 seems unrelated to the circuit? Or is it inPIX_CLOCK shown with an arbitrary delay? In this case, the relation to the input clock should be shown as well.
If trace 3 and 4 are recorded with correct delay, there's apparently a glitch causing the extra toggle. Although it's not fully visible in the waveform, it may be present internal to the CPLD. Most likely setup or hold timing of inPIX_CLOCK has been violated here.
