17 years agoEPM7128AE - strange FlipFlop behaviour
I use the scematic on EPM7128AE you'll see in schaltung.jpg. There is a pixelclock (signal 3) which should comes out of the JK-FlipFlop with half the frequency. This works fine but sometimes there...
17 years agoIt's normal behaviour with unrelated signals. A single DFF isn't enough synchronization to use the output as a ripple clock. It should work with a second DFF level. If the delay is an issue, you can operate both FF'S on different clock edges.
