ahmad_zaklouta
4 years agodifferential clock output in agilex
Hey!
I want to transmit a differential clock from 1 FPGA to another. I have been looking for a clock output buffer but didn't find it in the IP catalog. I only saw a GPIO IP.
can I use this as a clock buffer?
or Is it enough to choose a differential pair and assign the clock to the positive pin with "true differential pair" IO standard?
- YuanLi_S_Intel
You can use it. However, for clock output, i will still suggest you to use dedicated CLK output pin and also clock related IP for better signal quality.
- YuanLi_S_Intel
If you are using it as output CLOCK, it would be better for you to choose CLOCK related IP such as Clock Control Block (ALTCLKCTRL) or PLL.
- ahmad_zaklouta
ok. Is it enough to connect the output to the positive pin of the differential pair and have the following constraint:
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to clk_out_por I should use a GPIO buffer to make it differential?
