ahmad_zaklouta
4 years agodifferential clock output in agilex
Hey!
I want to transmit a differential clock from 1 FPGA to another. I have been looking for a clock output buffer but didn't find it in the IP catalog. I only saw a GPIO IP.
can I use this as a ...
YuanLi_S_Intel
4 years agoIf you are using it as output CLOCK, it would be better for you to choose CLOCK related IP such as Clock Control Block (ALTCLKCTRL) or PLL.
- ahmad_zaklouta4 years ago
ok. Is it enough to connect the output to the positive pin of the differential pair and have the following constraint:
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to clk_out_por I should use a GPIO buffer to make it differential?
