Takashi69's avatar
Takashi69
19 hours ago
Different FPGA model shows: DEV-AGM039EA
Dear Altera Team,
Thank you for your support.
We have received the following inquiry from our customer regarding the development kit DK-DEV-AGM039EA.
When checking the device using the tool, the FPGA device recognized by the tool appears to be different from the device listed in the catalog.
Catalog device: **AGMF039R47A**
Device detected by the tool: **AGME039R47A**
Could you please confirm whether the correct FPGA device is implemented on this development kit?
Additionally, the customer is currently conducting evaluation work with a target completion date of **March 20**. However, since the FPGA device appears to be different, the sample design for the evaluation board does not run properly.
Along with confirming the FPGA device difference, could you also advise whether a **sample design compatible with AGME039R47A** is available?
Your advice would be greatly appreciated.
Kind regards,
Takashi
T4908715
1 Reply
  • Takashi69's avatar
    Takashi69
    For example
    https://www.altera.com/products/devkit/po-3207/agilex-7-fpga-m-series-development-kit-hbm2e-edition-3x-f-tile-1x-r-tile
    It is DK-DEV-AGM039EA: Agilex™ 7 FPGA M-Series Development Kit - HBM2e Edition page.
    And it shows,
    Device OPN(s) on BoardAGMF039R47A1E1VC
    But Tool shows AGME039R47A1E1VC not AGMF039R47A1E1VC as picture previously attached.
    So it not able to run.
    Could you give some advice?
    Kind regards,
    Takashi
