Different FPGA model shows: DEV-AGM039EA
For example
https://www.altera.com/products/devkit/po-3207/agilex-7-fpga-m-series-development-kit-hbm2e-edition-3x-f-tile-1x-r-tile
It is DK-DEV-AGM039EA: Agilex™ 7 FPGA M-Series Development Kit - HBM2e Edition page.
And it shows,
| Device OPN(s) on Board | AGMF039R47A1E1VC |
- AqidAyman_Altera4 months ago
Hello Takashi,
Firstly, I apologies for the delay response.
Regarding your issue here, from my understanding, you suspected the device on the board is having a different OPN that what was showing in the catalog and the website.
Here are my feedback and suggestions:
1- The device on the development kit with the ordering code: DK-DEV-AGM039EA should be AGMF039R47A1E1VC based on the user guide.
2- What is the Quartus version are you using? Can you try using 25.1.1 Pro Edition version?
3- Can you try to program the device with any provided .sof file located in the Installer Package of the development kit? For example, you can find bts_config.sof located in the \DK-DEV-AGM039EA_25.1.1b125_final\DK-DEV-AGM039EA_25.1.1b125\examples\bts_config\output_files directory.
4- Can you share the serial number of the development kit? If needed, you can privately share to me via private message.
Aqid- AqidAyman_Altera4 months ago
Hello Takashi,
I tried on the same development kit (DK-DEV-AGM039EA) that is available and found the same situation as what your customer reported.
When I use the Quartus Programmer "Auto Detect", it will show AGME039R47A. However, you may ignore this, as this device has the same Device ID as AGMF039R47A. Quartus will auto-choose which device comes first in its list that has the same Device ID detected. Refer here: https://docs.altera.com/r/docs/683748/current/agilextm-7-jtag-boundary-scan-testing-user-guide/device-id
When I try to program the file with the .sof file available in the Installer Package, it programs successfully. So, there is no issue. The development kit should have the correct device OPN, which is AGMF039R47AC.
Hello Takashi,
Any updates from you on this issue?Regards,
Aqid
