11 years agoDifference among Qsys Sim model, test-bench Qsys sys and test-bench Sim model
I'm confused about the purposes of different models that are offered during the generation process. In 'Generation' window you can have:
1) Simulation model 2) Test-bench Qsys system 3) Test-bench simulation model 4) Synthesis files (which I understand its purpose) My understanding is that (2) is a wrapper system that contains the Qsys system to be tested, it also contains BFMs that are connected to the top-level interfaces of the system to be tested. By writing another HDL file that drives the top-level interfaces, I can check the behaviour of the system. Q1: If the above is correct, now I want to do that in ModelSim, my guess is that having (2) alone is not enough, I also need (3) so that (2) can be simulated in ModelSim, is that correct? Q2: If my guess in Q1 is correct, then in what situation I may want to generate (2) alone without generating (3)? (I think this is explained in "Qsys System Design Tutorial" but I didn't quite follow it..) Q3: Is (1) a subset of (2)+(3)? My understanding is that (2)+(3) = (1)+(BFMs simulation model), is that correct? Q4: If I just want to test/simulate my Qsys system using standard BFMs in ModelSim, it is OK to unclick (1) and only use (2)+(3), is that correct?4 Replies
Your question is a little difficult to answer without knowing what sort of components you have added to your Qsys system.
Click on each of the options and look at the code generated. Typically I just generate a simulation model (in VHDL or Verilog depending on what I am doing). I then explicitly add BFMs or device models for testing. For example, when testing Avalon-MM slave components, I explicitly add an Avalon-MM master BFM to the design, eg., take a look at this tutorial; http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial In this thread (post# 25) http://www.alteraforum.com/forum/showthread.php?t=32952&page=3 I show how to use the master and slave BFM. I've also used the Qsys "Example Design" to get an idea of how to connect the DDR3 controller to a DDR3 model, and then rather than using that code, re-written a testbench in the style that I like. The key to understanding Qsys generated code is to read it as "example" code. If you do not like it, then its ok not to use it :) Cheers, Dave - Altera_Forum
--- Quote Start --- Your question is a little difficult to answer without knowing what sort of components you have added to your Qsys system. Click on each of the options and look at the code generated. Typically I just generate a simulation model (in VHDL or Verilog depending on what I am doing). I then explicitly add BFMs or device models for testing. For example, when testing Avalon-MM slave components, I explicitly add an Avalon-MM master BFM to the design, eg., take a look at this tutorial; --- Quote End --- Thanks Dave, So basically if I chose to generate test-bench qsys system and test-bench simulation model, the tool would generate a wrapper system containing an instance of DUT and another instance of BFMs, however if I did your way, DUT and BFMs would be within a single instance (BFMs are now virtually a part of DUT), a simulation model of such a single instance is equivalent to the simulation model of the wrapper system right? - Altera_Forum
--- Quote Start --- So basically if I chose to generate test-bench qsys system and test-bench simulation model, the tool would generate a wrapper system containing an instance of DUT and another instance of BFMs --- Quote End --- Right, but the caveat is that the BFMs are attached to the "external" interfaces of the Qsys system, whereas most times you would want an Avalon-MM master BFM as part of the Qsys system, otherwise how can you exercise your system? --- Quote Start --- however if I did your way, DUT and BFMs would be within a single instance (BFMs are now virtually a part of DUT), a simulation model of such a single instance is equivalent to the simulation model of the wrapper system right? --- Quote End --- Not quite. My method is a mixture. I add an Avalon-MM BFM to the Qsys system, so that I can read/write the Avalon-MM slaves at whatever addresses that BFM master is connected to (typically the same address map as another master), and then I create a testbench with an instance of the Qsys system, and then add BFMs manually to that testbench, eg., a DDR3 memory model. For testing Avalon-MM slave I/Os, I just test the state of the signals in the testbench stimulus process, and don't bother with BFMs. Cheers, Dave - Altera_Forum
I see. Thanks a lot!
