11 years agoDifference among Qsys Sim model, test-bench Qsys sys and test-bench Sim model
I'm confused about the purposes of different models that are offered during the generation process. In 'Generation' window you can have: 1) Simulation model 2) Test-bench Qsys system 3) Test-b...
11 years ago --- Quote Start --- So basically if I chose to generate test-bench qsys system and test-bench simulation model, the tool would generate a wrapper system containing an instance of DUT and another instance of BFMs --- Quote End --- Right, but the caveat is that the BFMs are attached to the "external" interfaces of the Qsys system, whereas most times you would want an Avalon-MM master BFM as part of the Qsys system, otherwise how can you exercise your system? --- Quote Start --- however if I did your way, DUT and BFMs would be within a single instance (BFMs are now virtually a part of DUT), a simulation model of such a single instance is equivalent to the simulation model of the wrapper system right? --- Quote End --- Not quite. My method is a mixture. I add an Avalon-MM BFM to the Qsys system, so that I can read/write the Avalon-MM slaves at whatever addresses that BFM master is connected to (typically the same address map as another master), and then I create a testbench with an instance of the Qsys system, and then add BFMs manually to that testbench, eg., a DDR3 memory model. For testing Avalon-MM slave I/Os, I just test the state of the signals in the testbench stimulus process, and don't bother with BFMs. Cheers, Dave
