11 years agoDifference among Qsys Sim model, test-bench Qsys sys and test-bench Sim model
I'm confused about the purposes of different models that are offered during the generation process. In 'Generation' window you can have: 1) Simulation model 2) Test-bench Qsys system 3) Test-b...
11 years ago --- Quote Start --- Your question is a little difficult to answer without knowing what sort of components you have added to your Qsys system. Click on each of the options and look at the code generated. Typically I just generate a simulation model (in VHDL or Verilog depending on what I am doing). I then explicitly add BFMs or device models for testing. For example, when testing Avalon-MM slave components, I explicitly add an Avalon-MM master BFM to the design, eg., take a look at this tutorial; --- Quote End --- Thanks Dave, So basically if I chose to generate test-bench qsys system and test-bench simulation model, the tool would generate a wrapper system containing an instance of DUT and another instance of BFMs, however if I did your way, DUT and BFMs would be within a single instance (BFMs are now virtually a part of DUT), a simulation model of such a single instance is equivalent to the simulation model of the wrapper system right?
