11 years agoDifference among Qsys Sim model, test-bench Qsys sys and test-bench Sim model
I'm confused about the purposes of different models that are offered during the generation process. In 'Generation' window you can have: 1) Simulation model 2) Test-bench Qsys system 3) Test-b...
11 years agoYour question is a little difficult to answer without knowing what sort of components you have added to your Qsys system.
Click on each of the options and look at the code generated. Typically I just generate a simulation model (in VHDL or Verilog depending on what I am doing). I then explicitly add BFMs or device models for testing. For example, when testing Avalon-MM slave components, I explicitly add an Avalon-MM master BFM to the design, eg., take a look at this tutorial; http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial In this thread (post# 25) http://www.alteraforum.com/forum/showthread.php?t=32952&page=3 I show how to use the master and slave BFM. I've also used the Qsys "Example Design" to get an idea of how to connect the DDR3 controller to a DDR3 model, and then rather than using that code, re-written a testbench in the style that I like. The key to understanding Qsys generated code is to read it as "example" code. If you do not like it, then its ok not to use it :) Cheers, Dave
