Aaron
7 months agoDevice migration about DD and DA
Hi Sir, 10M50DDF256C8G vs 10M50DAF256C8G My understanding is that the DD and DA packages are the same, or at least pin-to-pin compatible. However, when I tried using Quartus, I found that Device Mi...
Aaron
7 months agoHi Aqid,
I used 25.1standard.
as you mention you agree withboth OPN should be compatible with each other. Since the difference is only in the flash access control feature.
Future will modify at Quartus?
And can I confim to customer both OPN compatible with each other?
Aaron Hsu
AqidAyman_Altera
6 months agoHi Aaron,
The Device Migration window in Quartus is only applicable for vertical migration. Since this device has a difference in features, it depends on the design if you want to do a direct migration.
In other words, in terms of pinout, it is migratable. However, for design, it depends.
Aqid
