MartinMaa
1 month agoDedicated Clock Pins for MAX 10
Hello Intel Community, I am currently designing a system using the Intel MAX 10 FPGA, specifically the 10M02SCM153C8G in the compact M153 micro-package. Due to the highly constrained pin resource...
- 1 month ago
Hi Martin,
Pin Planner info is correct. Please compare with your previous post that confuses in- and outputs. Only difference is wheter PIN_L1 (outclk_n) can be alternatively used as single ended dedicated clock output. According to Quartus compilation result it can.
Regards Frank
FvM
1 month agoHi Martin,
Regards Frank
- AqidAyman_Altera1 month ago
Thank you, Frank, for the replies.
Hi Martin,
Do you have any other questions on top of Frank's reply?
Aqid
