MartinMaa
1 month agoDedicated Clock Pins for MAX 10
Hello Intel Community, I am currently designing a system using the Intel MAX 10 FPGA, specifically the 10M02SCM153C8G in the compact M153 micro-package. Due to the highly constrained pin resource...
- 1 month ago
Hi Martin,
Pin Planner info is correct. Please compare with your previous post that confuses in- and outputs. Only difference is wheter PIN_L1 (outclk_n) can be alternatively used as single ended dedicated clock output. According to Quartus compilation result it can.
Regards Frank
MartinMaa
1 month agoThank you.
