16 years ago
Debouncer verilog code
Hi you
I wrote a simple code for a debouncer circuit, and I appreciate if you can have a look and correct what's wrong.
module debouncer (noisy,clk_1KHz,debounced);
input wire clk_1KHz, noisy;
output wire debounced;
reg  cnt;
//counter: waits that button is pressed at least 10ms
always @ (posedge clk_1KHz)
begin
if (noisy) cnt <= cnt + 1'b1;
else cnt <= 0;
end
assign debounced = (cnt==4'b1010) ? 1'b1 : 1'b0;
endmodule
what you think about it?:confused:
thank you all
GP
    dear TCWORLD,
    I would like to clarify that this code is written by the
    Altera Teacher ARTEM_BOND and "reg" is authored by himself.
    I left exactly as he wrote, to not cause confusion.
    Below is my code which coincidentally, was exactly the name I used:
    module debounce(
        input wire clock,
        input wire IN,
        output reg OUT
     parameter M = 8;
     reg shift;
     //shift: wait for stable
     always @ (posedge clock)
     begin
       shift <= {shift,IN}; // N shift register
    // if(shift == (2**M)*0)
       if(~|shift)
         OUT <= 1'b0;
    // else if(shift == (2**M)-1)
       else if(&shift)
         OUT <= 1'b1;
       else OUT <= OUT;
     end
     endmodule
    If I understand correctly what you suggested, their changes are only to make the code cleaner...
    It really was it, nothing worked to help me, because nothing was fixed!!!
    As I requested earlier:
    ..."I think something is wrong in the code because I can notice any noise,
    by oscilloscope, even increased the value of M.
    Could you help me with this?"
    (Excuse me if not expressed myself correctly, my English is not very good.)
    • sintech's avatar
      sintech
      For someone who found this topic looking for a working debouncer.
      The correct code:
      module debounce(
          input wire clock,
          input wire IN,
          output reg OUT
       parameter M = 8;
       reg [M:0]shift;
       begin
         if(~|shift)
           OUT <= 1'b0;
         else if(&shift)
           OUT <= 1'b1;
         else OUT <= OUT;
       end
       endmodule
    Couple of suggestions:
    (1) Instead of doing:
    (reg == (2**M)*0)
    you could do:
    (~|reg)
    And similarly for:
    (reg == (2**M)-1)
    do:
    (&reg)
    Personally I think it looks cleaner.
    (2) It is really not a good idea to call a register 'reg'. 'reg' is a reserved keyword and should be used as the name. Perhaps a better name would be:
    reg  shift;
    Or something similar.
    dear ARTEM_BOND,
    I read your post, and I found their brilliant solution!
    I'm trying to build a simple and efficient verilog code, to solve the problem of noise...
    I made the following modification in your code, hoping to get a greater number of shifts:
     module debouncer (noisy, clock, debounced);
     input wire clock, noisy;
     output reg debounced;
     parameter M = 8;
     reg  reg;
     //reg: wait for stable
     begin
       reg <= {reg,noisy}; // N shift register
       if(reg == (2**M)*0)
         debounced <= 1'b0;
       else if(reg == (2**M)-1)
         debounced <= 1'b1;
       else debounced <= debounced;
     end
     endmodule
    reg  reg;
    begin
    reg <= {reg,noisy}; //shift register
    if(reg == 8'b00000000)
      debounced <= 1'b0;
    else if(reg == 8'b11111111)
      debounced <= 1'b1;
    end
    endmodule
