16 years agoDebouncer verilog code
Hi you I wrote a simple code for a debouncer circuit, and I appreciate if you can have a look and correct what's wrong.
module debouncer (noisy,clk_1KHz,debounced);
input wire clk_1KHz...
11 years agodear ARTEM_BOND,
I read your post, and I found their brilliant solution! I'm trying to build a simple and efficient verilog code, to solve the problem of noise... I made the following modification in your code, hoping to get a greater number of shifts:
module debouncer (noisy, clock, debounced);
input wire clock, noisy;
output reg debounced;
parameter M = 8;
reg reg;
//reg: wait for stable
always @ (posedge clock)
begin
reg <= {reg,noisy}; // N shift register
if(reg == (2**M)*0)
debounced <= 1'b0;
else if(reg == (2**M)-1)
debounced <= 1'b1;
else debounced <= debounced;
end
endmodule
I think something is wrong in the code because I can notice any noise, by oscilloscope, even increased the value of M. Could you help me with this?
