16 years ago
DDR input without DPA in Arria II GX
Hello
I am using arria ii gx to communicate with a high speed device. The device is sending DDR data, data with a data clock, dclk. dclk and data are source synchronous. I need to capture the data inside my Arria II GX FPGA, using dclk and separate it into a positive & negative edge streams.
The problem is that the skew between dclk and data, by the time they get into the FPGA, is unknown. Thus I want to be able to slide dclk or try different phases of dclk to capture the data. I was able to do this in Xilinx Virtex FPGAs using the iobdelay function, which allowed me to adjust the skew between dclk and data at run time. I want to do exactly the same in Arria II GX but I find no comparable option. I do not have a training pattern so the dpa is out. Can someone suggest a solution? Can I gain the ability to try various phases of dclk for sampling data in Arria II GX?
Thanks in advance for your help!!!
