16 years agoDDR input without DPA in Arria II GX
Hello I am using arria ii gx to communicate with a high speed device. The device is sending DDR data, data with a data clock, dclk. dclk and data are source synchronous. I need to capture the d...
16 years agoJake
The DDR clock and data from the device will come into the FPGA when the FPGA board is connected to the other board. However, I plan to run the FPGA using a clock from an on-board (FPGA board) oscillator. That should not be a problem, right?
