16 years agoDDR input without DPA in Arria II GX
Hello I am using arria ii gx to communicate with a high speed device. The device is sending DDR data, data with a data clock, dclk. dclk and data are source synchronous. I need to capture the d...
16 years agoJake
I know Stratix has that feature. Unfortunately, I need to find a way of achieving it on Arria II GX. The PLL dynamic phase change looks promising. But I will be limited to only 8 possible phases because M=1, N=1 would make the VCO frequency same as input frequency and thus I would loose the 'fine tuning' that would have been available if my VCO frequency were higher. Do you think the following scheme can work? ** Use a PLL ** PLL ref clock is DDR input clock ** PLL in normal mode ** M=N=1 ** PLL output clock is used to sample input data ** Use Dynamic Phase shifting inputs of PLL to move PLL output clock to optimum sampling position Regards
