17 years ago
Data corrupted, any problem with VHDL codes
HI everyone.
I just have a quick question to ask.
When we use the LOOP in VHDL, is there any chances that the number of times the LOOP is repeated affects the data, say, in the following piece of code, the code "content(i) <= content(i+1)" is repeated 65 times (content is an array of 8bit number), and the data I get at the output of the Modules (dataout[7:0]) is corrupted at some points:
-- ram.vhd
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity RAM is
generic ( bits: integer := 8;
words: integer:= 66);
port (clk_in: in std_logic;
clk_out: in std_logic;
we: in std_logic;
re: in std_logic;
reset: in std_logic;
datain: in std_logic_vector(bits - 1 downto 0);
dataout: out std_logic_vector(bits - 1 downto 0)
end RAM;
architecture beh of RAM is
signal readp: integer range 0 to words;
type table is array (0 to words - 1) of std_logic_vector(bits-1 downto 0);
signal content: table :=(others => "10000000");
begin
process(reset,clk_in, we)
begin
if (reset = '1') then
content <= (others => "10000000");
elsif (clk_in'event and clk_in = '1') then
if (we = '1') then
for i in 0 to words - 2 loop
content(i) <= content(i+1); --***could it be this line? ***
end loop;
content(words - 1) <= datain;
end if;
end if;
end process;
process(clk_out, re)
begin
if (clk_out'event and clk_out = '1') then
if(re = '1') then
dataout <= content(readp);
end if;
end if;
end process;
process(clk_out, re, reset)
begin
readp <= 0;
elsif (clk_out'event and clk_out = '0') then
if(re = '1') then
readp <= readp + 1;
if(readp = words - 1) then
readp <= 0;
end if;
end if;
end if;
end process;
end beh;
Any suggestion would be greatlly appreciated.
Cheers.
J.
    YEAHHHH, EXCELLENT, I've just tried to put a CLKINT (which make the clock line global) and the problem disappears. I have had some problems which were solved by using a CLKINT before, but didn't know why it helped. Now turns out it's all about the clock skew problem.
    Yeah, it is a correlator that I'm designing, I tried 2 methods, the other was to use a series of Shift register and Multipliers, but no way it's fit in the chip I was given. The MAC method involves so many problems, it's a nightmare.
    Could you think of any other methods?
    J.
    --- Quote Start ---
    J.
    --- Quote End ---
    Glad to help!
    Whilst I have designed a number of correlators ours always have to run flat out so we sacrifice resources to get speed (and use quite large FPGAs). The current one has 140 parallel accumulators and recirculates the complex PN sequence in a 2bit wide 80 bit long shift register (rather than circulating the 24 bit wide data). I've also implemented the same correlator as a Matched Data Filter arrangement - they take more or less the same resources.
    In your case you could maybe reduce the resource usage by changing from using a shift register to using a Circular buffer which would more easily map into a RAM (assuming your Actel has RAMs). The VHDL would be a little bit more complex but the synthesised logic would be much smaller.
    Mark.
