Hi Brian,
Thank you for the update.
My understanding is that it would be difficult to justify reverting this change, as it was introduced to address a known issue. Therefore, we do not anticipate reverting the behavior at this time.
That said, please feel free to let us know if you encounter any issues during the installation or migration process. We will be happy to assist and provide guidance as needed.
Need time on my side to under go this testing.
Please hold onto this ticket.
As for your reply do you mean it cannot override this error fail like the PCIe soft reset force setup via qsys or ip file change "xxx=True" ?
- CheepinC_altera10 days ago
Hi Brian,
Regarding the Quartus Fitter error, your understanding is correct. The error check and its associated trigger are implemented within the Quartus software itself, rather than within the IP files. As a result, the behavior is determined by the Quartus version being used, independent of the generated IP files.
Please let me know if you have any further questions or if there is anything else I can assist with.
Thank you.
- BrianSune_Froum8 days ago
Contributor
I have one unconfirmed information from:
https://community.altera.com/kb/knowledge-base/why-does-the-transceiver-tx-simplex-sends-wrong-data-when-the-cmu-pll-of-pciex1-/342679
The wrong data is only affected by the CMU PLL or not affected when fPLL is used?
This require your internal database info.Thanks
CheepinC_alteraI still need a confirmation on the CMU PLL wrong data situation it is only introduced via CMU PLL or both fPLL case?
Yes 17.1 shows a huge different on fittering
CH4 now can place and fit with the previous debug project.
Final result rolling back the entire project from 18.1 or 20.1 to 17.1 and boot via HPS + RBF shows success result on custom protocol via f-PLL and 4 channel PCIe However due to the inherent bottlenecking the 4 channel performance is not great in the first place.
I enclosed a log for reference.
- CheepinC_altera5 days ago
Hi Brian,
I checked the internal case associated with the KDB and did not find any references to the fPLL. Based on the available information, the internal discussions appear to focus exclusively on the CMU PLL.
Could you please share more details regarding your note with fPLL in previous response ie source of information? This would help me investigate further and clarify.
I look forward to your response.
- BrianSune_Froum5 days ago
Contributor
I am very confused. If there internal original discussion only related to CMU PLL case then why block and forbidden the fittering to place fPLL in the first place?
This make no sense.
For Quartus 17.1 I simply do a very basic placement on fPLL + hard PCIe like what you had done in 20.1 and no fittering issue. So I move onto real design project and simply roll back all IP via tcl script and regenerate necessary rbf and loaded via HPS.So real system shows no issue on both custom protocol and PCIe via NVMe testing see the log.
However The PCIe RP itself is very slow which bandwidth can only achieve 400MB/s under x4 GEN 1.
Either how it is still working properly under 17.1 via fPLL and shared reconfiguration as we both discussed in this long conversation.
I had also enclosed the placement image that you can see the top fPLL is used along side the with big hard PCIe block.Thanks,
Brian
Hi Brian,
If I understand your previous note correctly, you have tested the PCIe HIP design using the fPLL, and the design is able to pass Fitter and operate successfully on CV hardware. To ensure we are aligned, would you mind sharing the QAR for the test project? Having a look at the design will help me better understand the configuration and setup used in your test.
I believe the test design I previously provided was using the CMU PLL for the PCIe HIP, so it would be helpful to compare the two implementations.
Thank you, and I look forward to your response.
Contributor
No the PCIE hard IP cannot modify from user side it is a must on CMU PLL while this limits the use of fPLL placement on remains channels when >= 18.0 Quartus.
The report from the your link only mentioned the TX wrong data and did not clearly mentioned it is on PCIe side or custom channels so this is a bit hard to understand if only CMU PLL is introducing possible issue on remains channel why fPLL would be blocked to use in the first place. Unless the CMU PLL introduce wrong data to hard PCIe as well.A table maybe clear up things more better:
PCIe Hard PLL PCIe GEN PCIe xN Remain channels Remain PLL Remain xN Reconfig Quartus Result CMU 1 4 2 fPLL 2 Shared 17.1 Pass CMU 1 4 2 fPLL 2 Shared 18.1 Fit Error CMU 1 4 2 fPLL 2 Shared 20.1 Fit Error Meantime, the reconfiguration also successfully tested on our side with modification of Vod and Pre-emphasis first post-tap. Which these two are the most important in most use cases. The recfg shows no issue on register read return status.
Functional-wise also show normal behavior on real hardware.CheepinC_altera - Waiting on your internal investigations result.
So back to the original question, what actually the report really referring to? The CMU PLL creates wrong data along with CH1 / CH4? And why only PCIe x1 use case not x2 x4?
So the report is referring to the channel NOT the PCIe itself but custom or other protocol use case on those remains channel.
However fPLL is complete isolated with the CMU PLL generated clock both // & ser. so there are no possible correlation on wrong data latching between xN x1 x6 clock lanes. How could this even possible to restrict the use and fit for fPLL use cases?
Make zero sense, unless the Mbps and MHz both fPLL and CMU PLL is the same or sub ordering that could introduce "harmonic spurious" or "high jitter" that violates the timing setup hold slacks.
Cannot understand why >= 18.0 ban user to fit channel that is possible to use in first place. 😞😞😞
Brian
