12 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 100 MHz to the rest of the design.
However I am having problems, I made a SDC and I am having timining problems, says my fmax of the ALT PLL output is 91.73 MHz. I used to use altpll and everything used to work, but altppl is not compatible to Cyclone V so I have to use the Altera PLL. What can I do? I've played a little bit with Quartus II configurations and the sdc file but it was useless...13 Replies
--- Quote Start --- Thanks for your answer, which FPGA have you used? Did you connect more than one component to the F2H/H2F/H2F_LW bridge? I have the problem when I connect a DMA and the TSE Mac to the F2S bridge. --- Quote End --- Dear Aprado, For example: Several Altera DMAs inserted and tried on FPGA side, which utilized F2H bridge. The FPGA-SDRAM interfaces has not been used, yet. Target platform was Cyclone V SoC DB rev.D (5CSXFC6D6F31C6). TSE MAC : Why are not you use the HPS' EMAC instead of FPGA TSE_MAC? Zs.V - Altera_Forum
--- Quote Start --- I have also a question: How you can re-assign FPGA pins at the your PCB design procedure without the usage of FPGA Pin planner. Unfortunately, I observed, that in all latest versions of Quartus (13.0 - 14.0) the Pin planner (Live checker) does not function properly : " Live I/O check is currently not supported by the "<name>" family. (ID: 168014) http://quartushelp.altera.com/14.0/master.htm#mergedprojects/msgs/msgs/efiochk_live_io_check_not_supported_for_family.htm " Regards, Zsolt --- Quote End --- Answer for my question: The "Early IO Assignment Analysis" or "IO Analysis before a compilation" might be an alternative solution instead of Live I/O checker. The "I/O Assignment analysis" (Pin Planner) was successfully tested for Cyclone V SoC. Moreover, Live IO check will not be supported in the current (14.0) and future release for Cyclone V. Zs.V. - Altera_Forum
Thank you very much for your answer, unfortunately I have some custom IP which interfaces directly with the TSE MAC.
Cheers --- Quote Start --- Dear Aprado, For example: Several Altera DMAs inserted and tried on FPGA side, which utilized F2H bridge. The FPGA-SDRAM interfaces has not been used, yet. Target platform was Cyclone V SoC DB rev.D (5CSXFC6D6F31C6). TSE MAC : Why are not you use the HPS' EMAC instead of FPGA TSE_MAC? Zs.V --- Quote End ---
