12 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 1...
12 years ago --- Quote Start --- I have also a question: How you can re-assign FPGA pins at the your PCB design procedure without the usage of FPGA Pin planner. Unfortunately, I observed, that in all latest versions of Quartus (13.0 - 14.0) the Pin planner (Live checker) does not function properly : " Live I/O check is currently not supported by the "<name>" family. (ID: 168014) http://quartushelp.altera.com/14.0/master.htm#mergedprojects/msgs/msgs/efiochk_live_io_check_not_supported_for_family.htm " Regards, Zsolt --- Quote End --- Answer for my question: The "Early IO Assignment Analysis" or "IO Analysis before a compilation" might be an alternative solution instead of Live I/O checker. The "I/O Assignment analysis" (Pin Planner) was successfully tested for Cyclone V SoC. Moreover, Live IO check will not be supported in the current (14.0) and future release for Cyclone V. Zs.V.
