12 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 1...
12 years ago --- Quote Start --- Thanks for your answer, which FPGA have you used? Did you connect more than one component to the F2H/H2F/H2F_LW bridge? I have the problem when I connect a DMA and the TSE Mac to the F2S bridge. --- Quote End --- Dear Aprado, For example: Several Altera DMAs inserted and tried on FPGA side, which utilized F2H bridge. The FPGA-SDRAM interfaces has not been used, yet. Target platform was Cyclone V SoC DB rev.D (5CSXFC6D6F31C6). TSE MAC : Why are not you use the HPS' EMAC instead of FPGA TSE_MAC? Zs.V
