12 years agoCyclone V Altera PLL Can't do 100 MHz.
Hello, I am desiging a custom board based on the Altera Cyclone V board. I've changed the board oscillator from 50 MHz to 100 MHz. I am trying to make it go throught a PLL inside QSys and then feed 1...
12 years agoThank you very much for your answer, unfortunately I have some custom IP which interfaces directly with the TSE MAC.
Cheers --- Quote Start --- Dear Aprado, For example: Several Altera DMAs inserted and tried on FPGA side, which utilized F2H bridge. The FPGA-SDRAM interfaces has not been used, yet. Target platform was Cyclone V SoC DB rev.D (5CSXFC6D6F31C6). TSE MAC : Why are not you use the HPS' EMAC instead of FPGA TSE_MAC? Zs.V --- Quote End ---
