Cyclone IV and Nios II Firmware Update
Hallo Everybody,
I would like you guys to suggest a solution for the problem below: I have successfully updated the hardware and software configurations of my project on the EPCS device and have tested the device by resetting it. Everything works perfectly. Now I did my experiments with the Nios II flash programmer. And there were no problems. now considering a situation where a connection through the jtag interface is not available, i would like to perform the update also through a fieldbus or ethernet. i have already read up on preparing the configuration files to be written to the flash (elf2flash, sof2flash). i can also transfer the files and store it in the flash memory. now my question is, if i am using the default epcs boot copier, do i write the fpga configuration first and then the software application, one after the other on to the flash?? or is there a specific rule, how i store these files on to the flash memory? If there are any other posts or documentation that I can read with respect to this issue, please let me know. Thank you very much Cheers kaushik.24 Replies
If you still have not successfully booted your software from flash, I highly recommend you use the --after tag. Is there a specific reason why you aren't using it?
You might want to check out http://www.alteraforum.com/forum/showthread.php?t=27981 (http://www.alteraforum.com/forum/showthread.php?t=27981). This thread has someone fighting to get the same sort of setup you are hoping for. - Altera_Forum
@kosh271 -- Actually i am using the After tag.. Since I am not getting the desired results with that.. I am thinking of not using it in my next attempt. My hardware and software flash files have been concatenated to become a single .bin file.. So the software data is obviously after the hardware file.. So I dont how the after tag makes sense here..
and the link you provided does not actually explain the same problem.. I am not using the NIOS2 flash programmer at all.. My Flash files find their way to the Flash using a fieldbus protocol. Do you have any links that explain this process?? or Methods to boot and update firmware without using the JTAG connection... - Altera_Forum
In the default development process,the bootloader load firmware(elf) from the address just after the sof file,because the bootloader can calculate the size of sof file.The default development process can be used to develop factory image(include sof and elf file and sof file offset in EPCS is 0x0).For user image(the sof and elf file offset in EPCS is user defined) you can use the bootlaoder generated by programe which download from the alterawiki.
In default development process, the"--after" option can make the flash file generated from elf have an offset in EPCS, the offset is the size of sof file. flash file contain the address infomation in it's formate. - Altera_Forum
--- Quote Start --- If I am comparing the flash contents, its all a bunch of ones and zeroes.. How do I know, what exactly went wrong?? --- Quote End --- There are some tools that can be used to compare flash files. IIRC the "verify" option in the Quartus programmer will just tell you "failed" if there is a difference, without telling you more information. But if you read back the flash contents and use a tool such as srec_cmp from the srecord package (http://srecord.sourceforge.net/) can give you more information about differences between to flash files. - Altera_Forum
Here is another question:
I am writing the complete concatenated bin-file in to the flash with one single flash write function. That means that the hardware and the software firmwares are actually placed one after the another irrespective of the "Blocks" in the flash. Do I need to worry about this?? I mean, should I first write the hardware firmware and if it ends in the middle of a flash block, then start writing the software firmware in the next block?? I would like to thank all of you for your previous answers.. - Altera_Forum
Hey Guys,
I have another question. The EPCS bootloader sources that i found in my NIOS installation folder, only contain files up to Cyclone III. I mean, the Cyclone III bootloader file is automatically added to my Quartus EPCS configuration, but I use a Cyclone IV device. Is this bootloader, basically compatible with the Cyclone IV device?? Thanks. - Altera_Forum
About your first question, the software should be written into the flash just after the FPGA image. AFAIK the bootloader isn't block aware, and will just get the FPGA image size from it header in the first few bytes, jump over it and start reading the elf image.
For your second question there isn't any significant difference in that area between the Cyclone III and IV so it should work. I have several projects here on Cyclone IV with the standard EPCS boot loader and they boot fine. - Altera_Forum
Thanks Daixiwen for your answer..
I cannot still get the software to boot.. It got me thinking. I looked at the nios2-flash-programmer logs and the flash programmer actually adds a little more data to the nios2 firmware before it copies it into the location after the hardware firmware. I mean, do I need to add something like address information, or pack the .bin file in to a Boot record before I flash it. If yes, then could you please give me a example?? Thanks a lot. - Altera_Forum
as far as I know the only thing the flash programmer does is convert the elf file to a srec file before flashing it. As long as your binary file has the same contents than this srec file it should work.
How do yo generate your binary file to flash? - Altera_Forum
I transfer the bin file to my device through ADS over EtherCAT protocol. I have checked at the receiving end if there is any dataloss but the data is intact. And then I use the alt_write_flash function to write the whole data in to my flash device with offset as '0' and length equal to the my file size.
Please find below the commands that I use to convert my flash files to a bin file. Are they alright?? sof2flash --input=widrive.sof --output=widrivehardware.flash --epcs --verboseelf2flash --input=drive_fpga.elf --output=widrivesoftware.flash --epcs --after=widrivehardware.flash --verbose
nios2-elf-objcopy -i srec -o binary widrivesoftware.flash softwarefirmware.bin"
nios2-elf-objcopy -i srec -o binary widrivehardware.flash hardwarefirmware.bin"
cat softwarefirmware.bin hardwarefirmware.bin > firmware.bin
