14 years agoCyclone IV and Nios II Firmware Update
Hallo Everybody, I would like you guys to suggest a solution for the problem below: I have successfully updated the hardware and software configurations of my project on the EPCS device ...
14 years ago --- Quote Start --- If I am comparing the flash contents, its all a bunch of ones and zeroes.. How do I know, what exactly went wrong?? --- Quote End --- There are some tools that can be used to compare flash files. IIRC the "verify" option in the Quartus programmer will just tell you "failed" if there is a difference, without telling you more information. But if you read back the flash contents and use a tool such as srec_cmp from the srecord package (http://srecord.sourceforge.net/) can give you more information about differences between to flash files.
