14 years agoCyclone IV and Nios II Firmware Update
Hallo Everybody, I would like you guys to suggest a solution for the problem below: I have successfully updated the hardware and software configurations of my project on the EPCS device ...
14 years agoIf you still have not successfully booted your software from flash, I highly recommend you use the --after tag. Is there a specific reason why you aren't using it?
You might want to check out http://www.alteraforum.com/forum/showthread.php?t=27981 (http://www.alteraforum.com/forum/showthread.php?t=27981). This thread has someone fighting to get the same sort of setup you are hoping for.
