14 years agoCyclone IV and Nios II Firmware Update
Hallo Everybody, I would like you guys to suggest a solution for the problem below: I have successfully updated the hardware and software configurations of my project on the EPCS device ...
14 years ago@kosh271 -- Actually i am using the After tag.. Since I am not getting the desired results with that.. I am thinking of not using it in my next attempt. My hardware and software flash files have been concatenated to become a single .bin file.. So the software data is obviously after the hardware file.. So I dont how the after tag makes sense here..
and the link you provided does not actually explain the same problem.. I am not using the NIOS2 flash programmer at all.. My Flash files find their way to the Flash using a fieldbus protocol. Do you have any links that explain this process?? or Methods to boot and update firmware without using the JTAG connection...
