14 years agoCyclone IV and Nios II Firmware Update
Hallo Everybody, I would like you guys to suggest a solution for the problem below: I have successfully updated the hardware and software configurations of my project on the EPCS device ...
14 years agoI transfer the bin file to my device through ADS over EtherCAT protocol. I have checked at the receiving end if there is any dataloss but the data is intact. And then I use the alt_write_flash function to write the whole data in to my flash device with offset as '0' and length equal to the my file size.
Please find below the commands that I use to convert my flash files to a bin file. Are they alright?? sof2flash --input=widrive.sof --output=widrivehardware.flash --epcs --verbose
elf2flash --input=drive_fpga.elf --output=widrivesoftware.flash --epcs --after=widrivehardware.flash --verbose
nios2-elf-objcopy -i srec -o binary widrivesoftware.flash softwarefirmware.bin"
nios2-elf-objcopy -i srec -o binary widrivehardware.flash hardwarefirmware.bin"
cat softwarefirmware.bin hardwarefirmware.bin > firmware.bin
