14 years agoCyclone III with 5v inputs
I'm trying to connect approximately (16) 5v TTL inputs into a Cyclone III eval board, the terasic de0 [1]. These are all input towards the FPGA only. The eval board has (2) 40-pin IDC headers for the free I/O pins.
I've read something about a first generation Cyclone that using the internal PCI clamps, and an external resistor to bring 5v into the board. I don't believe this will work for the III, but needed advice before I proceed to spend $$$ and time on an alternative solution. I'm also concerned about AN 447: Interfacing Cyclone III and Cyclone IV Devices with 3.3/3.0/2.5-V LVTTL/LVCMOS I/O Systems. [2] I guess I should worry about the overshoot. Of course I searched the forums before posting, and did get some valuable information from one recent post. [3] Searching the forum for very short keywords like "5v" and "ttl", or even "5v ttl" doesn't work well. I was going to create a small custom PCB that sits between the eval board and the inputs. The output towards the FPGA board is a 40-pin IDC connector using a standard old school hard drive cable. The input to the board will be via a single row of .1 on center male header pins. I'm going to use 6" cables from those pins to a chip clip that will connect to a DIP in another system that is primarily 5v only. The PCB will have at the center (2) 74LCX245 sold by NKC electronics. [4]. [5]. I was also going to put a ~500ohm resistor in line with the output of the transceiver towards the FPGA with the hopes of both meeting the sample circuit in the 245 datasheet and also for the series termination/minimizing reflection purposes in the 447 application note. The eval board has VCCIO locked to 3.3v and presents 3.3v on the 40-pin header, which I can use to power VCC on the LCX245. The signals are at either 7.15mhz or twice that rate, 14.3mhz. Does this sound reasonable? I'd appreciate any ideas on improving it. This is a one-off prototype design that will probably never leave my basement, but will likely be documented online. This will be my first custom PCB. Thanks, Keith [1] http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&no=364 [2] http://www.altera.com/literature/an/an447.pdf [3] http://www.alteraforum.com/forum/showthread.php?t=30591 [4] http://www.nkcelectronics.com/5v-to-33v-logic-level-shifter-bo.html [5] http://www.fairchildsemi.com/ds/74/74lcx245.pdf
