15 years agoCyclone III with 5v inputs
I'm trying to connect approximately (16) 5v TTL inputs into a Cyclone III eval board, the terasic de0 [1]. These are all input towards the FPGA only. The eval board has (2) 40-pin IDC headers for t...
15 years ago --- Quote Start --- The TI 74CBTD3384C http://www.ti.com/lit/ds/symlink/sn74cbtd3384c.pdf buffers used on the MAX II PCI development kit are bus-switches with the diode internal to the device. You can power them from 5V and they'll clamp bidirectional signals to 3.3V levels. I've used a bunch a bus switches on lots of designs, but never realized they had parts with the diodes internal to the devices. Cheers, Dave --- Quote End --- Thanks Dave for your help. I would certainly prefer something with less external parts required. I sampled these today from TI, although they only had the DBQ(SSOP/QSOP) parts available. I prefer SOIC with the larger 1.27mm pitch. I've soldered the SOIC before, and they weren't bad. The SSOP have half the pitch. Any experience hand soldering these? Thanks, Keith
