15 years agoCyclone III with 5v inputs
I'm trying to connect approximately (16) 5v TTL inputs into a Cyclone III eval board, the terasic de0 [1]. These are all input towards the FPGA only. The eval board has (2) 40-pin IDC headers for t...
15 years ago --- Quote Start --- can i attach the output of the ti chip directly to the connector going to the cyclone iii? ie without a series resistor? --- Quote End --- Yes. If a source termination is required, it would be needed back at the source driving the input to the bus switch. --- Quote Start --- should i connect the fpga ground to the ground of the system i'm receiving the 5v ttl from? --- Quote End --- Yes. Without it, your interface will not work. If you need an isolated interface, then Analog Devices has some nice parts; look for iCoupler. Cheers, Dave
