15 years agoCyclone III with 5v inputs
I'm trying to connect approximately (16) 5v TTL inputs into a Cyclone III eval board, the terasic de0 [1]. These are all input towards the FPGA only. The eval board has (2) 40-pin IDC headers for t...
15 years agoLast, but not least,
if I use pull-downs on the buffer inputs like you mention here (http://www.alteraforum.com/forum/showpost.php?p=123853&postcount=8) What size pull-down should I use? This will make sure that the buffer always has some valid value --- if not asserted from the device it's connected to, then at least ground from the pulldown. Thanks Keith
