15 years agoCyclone III with 5v inputs
I'm trying to connect approximately (16) 5v TTL inputs into a Cyclone III eval board, the terasic de0 [1]. These are all input towards the FPGA only. The eval board has (2) 40-pin IDC headers for t...
15 years ago --- Quote Start --- if I use pull-downs on the buffer inputs like you mention here (http://www.alteraforum.com/forum/showpost.php?p=123853&postcount=8) --- Quote End --- There is a big difference between using a buffer and a bus-switch. A bus-switch can be used for bi-directional clamping of signals. The bi-directional nature of this solution means that you can use the pull-ups on the FPGA I/O pins to guarantee that the I/O pins are at a valid logic level at all times. No need for pull-ups on your bus switch board. Cheers, Dave
