15 years ago
Cyclone III FPGA set to I/O mode
Hello all,
well i am a bit new to Cyclone III FPGA,
so, the problem i am having is a bit strange. i have made VHDL IP-core, which worked fine previously on my MAX-II CPLD, but now i wanted to run the same IP-Core on my Cyclone III, but i am getting unexpected outputs to some of the IO pins, the real core works fine, but i get unknown or unexpected results over other pins (even if i set all unused pins to tristate in Quartus II). so now i think it would be that my fpga is not configured in Only IO mode or so, and this is the reason i get additional results, so can any one help me in this regard??? or tell me that how can i configure my fpga to only for IO mode.
looking forward for support
    --- Quote Start ---
    It Worked :), thanks a-lot for the help.
    as for your interest, i had following findings
    well the output results were the same when set to "tri-state with weak pull-up" (i.e. everything still not working),
    but every thing get normal when i changed it to "as input tristate with bus hold circuit" now the core is working as it should !!!
    thanks,
    regards.
    --- Quote End ---
    Thanks for sharing this, but it still makes me wonder why. Any idea? Frank?
    -- Ton
    --- Quote Start ---
    --- Quote End ---
    Unfortunately not. I expected the SDRAM to be deactiveted reliably by weak pull-ups. Theer must be something special with the circuit.
    The more interesting question is, if the final design will work. Good luck!
    Frank
    Hello Again.
    well after, looking again and again to my design, i come to few conclusions i want to share.
    the problem was actually not resolved by changing the configuration to weak pull up or bus-hold.. at that time it worked accidentally as i also made few changes to design as well.. but still at that time it seemed resolved, and working fine, BUT not as in past few dayz i added some more functionality to the design and the problem was back again, which was very annoying..as all my work was stopped because of this problem...
    any how.. the final conclusion is important to be notice.. and which is.. that it turned out that i have some unused or un-assigned ports (debug ports, input and output) in my design (in BDF design file) which didnt give any problem in my Altera CPLD training kit, but here in FPGA that was the problem. .. i removed all those test ports, and recompile the design. so everything started to work as it should ...
    now finally i can move on with my work :)...
