16 years agoCyclone III FPGA set to I/O mode
Hello all, well i am a bit new to Cyclone III FPGA, so, the problem i am having is a bit strange. i have made VHDL IP-core, which worked fine previously on my MAX-II CPLD, but now i wanted to r...
16 years ago --- Quote Start --- It Worked :), thanks a-lot for the help. as for your interest, i had following findings well the output results were the same when set to "tri-state with weak pull-up" (i.e. everything still not working), but every thing get normal when i changed it to "as input tristate with bus hold circuit" now the core is working as it should !!! thanks, regards. --- Quote End --- Thanks for sharing this, but it still makes me wonder why. Any idea? Frank? -- Ton
