Cyclone 10 LP's Extended Industrial parts
Hi AqidAyman_Altera and Frank,
I tried again with Standard Edition v25.1 and was able to set 125 C as shown below.
Thank you for pointing it out.
Captured data:
From this result above, is the following my understanding correct?
We can order Industrial Grade product in device OPN and develop the design after setting as same as Extended Industrial Grade (-40degC to +125degC) on Quartus Standard Edition.
I wait for your answer to following question.
2. If the device OPN is listed as Extended Industrial grade, then you may choose the same OPN in EPE.
I keep trying to download the Cyclone 10 LP EPE, but I get an error below. Can you download it? If yes, please share it.
https://www.altera.com/design/resource/power/epe-and-pa#faq
MAC_Yossi
Hi MAC_Yossi
I have confirmed two things.
1. Yes, your understanding is correct. However, only selected Cyclone 10 LP OPNs support the Extended‑Industrial temperature grade, and these are the devices that use the core‑voltage option ‘Y’. Devices using the core‑voltage option ‘Z’ do not support the Extended‑Industrial temperature grade.
2. There is no price difference between Industrial & Extended Industrial OPN.
Aqid
