Cyclone 10 LP's Extended Industrial parts
Hi AqidAyman_Altera and Frank,
I tried again with Standard Edition v25.1 and was able to set 125 C as shown below.
Thank you for pointing it out.
Captured data:
From this result above, is the following my understanding correct?
We can order Industrial Grade product in device OPN and develop the design after setting as same as Extended Industrial Grade (-40degC to +125degC) on Quartus Standard Edition.
I wait for your answer to following question.
2. If the device OPN is listed as Extended Industrial grade, then you may choose the same OPN in EPE.
I keep trying to download the Cyclone 10 LP EPE, but I get an error below. Can you download it? If yes, please share it.
https://www.altera.com/design/resource/power/epe-and-pa#faq
MAC_Yossi
- AqidAyman_Altera5 months ago
Hi MAC_Yossi
I have confirmed two things.
1. Yes, your understanding is correct. However, only selected Cyclone 10 LP OPNs support the Extended‑Industrial temperature grade, and these are the devices that use the core‑voltage option ‘Y’. Devices using the core‑voltage option ‘Z’ do not support the Extended‑Industrial temperature grade.
2. There is no price difference between Industrial & Extended Industrial OPN.
Aqid - AqidAyman_Altera5 months ago
Hi MAC_Yossi ,
Regarding the error in downloading the EPE file, we will work to update the links. As a workaround, you can go to docs.altera.com and search for the file name or asset ID. You can find the asset ID from the link path.
However, I do not find the Office 365 version. I am only able to find one of the files only. Please refer to the link below:
Aqid
- MAC_Yossi5 months ago
Hi Aqid,
I checked the following and understand what you mention about "option".
Operating Conditions:
Excerpt) Standard core voltage option (1.2 V)—"Y": For –C6, –C8, –I7, and –A7 speed grades
Table 3. Recommended Operating Conditions for Intel® Cyclone® 10 LP Devices:
Excerpt) VCCINT = 1.2-V operation 1.15V Min, 1.2V Typ, 1.25V Max
Also, I could get the EPE(Not Office 365 Version) for Cyclone 10LP from URL you reported.
MAC_Yossi
Hi MAC_Yossi
Thank you for your confirmation on the understanding.
May I know if there are any more questions from you regarding this?
