Cyclone 10 LP's Extended Industrial parts
Hi AqidAyman_Altera,
1. Refers to this KDB, it mentions that there is no difference between Industrial and Extended Industrial
in device OPN. Both will be used "I" as the letter to indicate the Operating Temperature.
I could Not completely understand that there is no difference between Industrial and Extended Industrial in device OPN. Please let us know your answer to questions below.
Q1-1. If so, we have to order Industrial Grade product in device OPN and develop the design after setting Extended Industrial Grade (-40degC to +125degC) on Quartus Standard Edition. Is it correct?
Q1-2. Is there no price difference between Industrial and Extended Industrial in device OPN?
Q1-3. The following URL on the KDB was not shown correctly, would you provide us what written in?
Extended Temperature Device Support:
2. If the device OPN is listed as Extended Industrial grade, then you may choose the same OPN in EPE.
I keep trying to download the Cyclone 10 LP EPE, but I get an error below. Can you download it? If yes, please share it.
https://www.altera.com/design/resource/power/epe-and-pa#faq
3. After selecting the device, if the device is supported for Extended Industrial grade, you may check it on Assignments - > Settings -> Temperature. This is the example for 21.1 Standard version:
I checked with the latest Quartus Standard Edition v25.1, but I could not set it to +125degC.
According to my colleague, if there is no .ini file in the past, it will not be enable.
Would you please check whether special .ini file is needed?
- AqidAyman_Altera5 months ago
Hi MAC_Yossi,
Yes, since there is no difference in the OPN for Industrial and Extended Industrial, I believe your understanding is correct.
Regarding the broken link inside the KDB has been reported internally. I will inform you once there is any updates on this.
For the Cyclone 10 LP EPE download error, I also observed the same problem. This problem has been acknowledged internally. I will update you back once get any updates.
Aid
