MAC_Yossi
6 months agoCyclone 10 LP's Extended Industrial parts
[Question] Customer have questions about Cyclone 10 LP's Extended Industrial (Tj = -40degC to 125degC) in the Product Catalog at the following URL. https://www.intel.com/content/www/us/en/content-d...
AqidAyman_Altera
6 months agoHello MAC_Yossi,
1. Refers to this KDB, it mentions that there is no difference between Industrial and Extended Industrial in device OPN. Both will be used "I" as the letter to indicate the Operating Temperature.
2. If the device OPN is listed as Extended Industrial grade, then you may choose the same OPN in EPE.
3. After selecting the device, if the device is supported for Extended Industrial grade, you may check it on Assignments - > Settings -> Temperature. This is the example for 21.1 Standard version:
